Hello all,
I'm new to the forum here -- I have a 16.5' CeeBee Avenger with a Johnson 140 outboard (1977). I've only owned the boat about 1.5 years and do not know about it's maintenance history.
It was running kind of poorly towards the end of last year and this season also. I got it running consistently at about 30%+ throttle, but it refuses to idle and noticeably runs rough at lower rpms.
I took it to a local boat place (Middleton, WI) a couple of days ago and just found out that it, apparently, has torn up one of the rings. I know enough to realize this is not good, but I need some advice beyond that.
I want the engine to be reliable. I'm not concerned about power (140 is more than plenty) and I don't want to spend a ton of money.
Is this the kind of problem I can fix myself? Parts are for sale online. I have never rebuilt an engine, but I am a bit mechanical.
Is it likely I would have to replace a piston along with the ring?
Can the engine be disassembled (enough to replace rings) while mounted on the boat?
I see pistons and rings online (for example: link). Looks like $69 for a piston and $27 for a ring. Are there many other costs involved that might come into play? Maybe some gaskets?
Any recommendations would be much appreciated. Thanks so much
