59Thompson
- Sep 10, 2009
- 74
Am looking for a booklet that discusses installing this motor i.e. wiring diagrams but also what type of key switch to use and how the motor is stopped. The Thompson I am getting has been cobbled up with mixed wire colors and it does not appear the harness is correct for the motor and solenoid box. Would appreciate it if someone has a Johnson or Evinrude guide on installation if not a Gale. The motor has electric and manual start, electric choke and no generator. The shift is manual using a Simplex Bosun unit. Thanks for any help you can provide. Regards, John
