TheStinkMan
- Feb 26, 2010
- 16
I recently purchased a 92 Nitro 180 that has a 1991 Evinrude 150 XP. Performed a compression check and the bottom left cylinder was at 70 (Bottom Left looking from the back of the boat to the front) all others were 95-100. I pulled the head on that side and the piston head is melted. The head and cylinder walls look good. I see no other damage. Wondering if I have to pull the entire block to replace the piston or can I pull the carbs and reed box to R&R the piston with a new one? Engine Model Number: TE150SLEIE
