Re: Piston rings for 40 Hp Johnson RD-22
Awesome! Then you should be good to go with a re-ring job.
I see tiller handles too. Kind of a rare find on one of these.
Those are good engines and quite reliable, but be careful that you don't let it runaway on you. These models 1960 - 61 were notorious for twisting the cranks, in a runaway situation. This is mostly because they still used the same crank as the 35, but increased the bore diameter. The flywheel is also pretty heavy too. Just make sure that the cut out solenoids are in good working order. They ground out the ignition system should a runaway situation occur.
In 1962, they redesigned the 40's with a heftier crank and a two ring piston. You'll also notice that the compression releases were no longer on the heads, from '62 on. These are still good motors and still are lots of them around.
Good luck with the rebuild. I think it'll turn out great.
