The engine starts and idles OK, but has very little power. I do not have a working tachometer but am guessing it will only turn about 1500 RPM under load at WOT. It will rev up quite high when out of gear when using the fast idle lever, but it has to warm up a bit before it will rev up even then. Any help you can give me?
