ThanK You in advance for this great forum & all the outboard savy contributors
I was about to run through the Reeves Link & Sync procedure & set the spark tester for 7/16" (motor has been bogging under load)
Decided to check spark on each cyl, and guess I am not getting any spark on number 3.
So is there other checks I need to make before replacing the coil?
This motor is a 1977 75hp Model 75743s
Todd Aka DenSVXer
Littleton, CO
Todd Aka DenSVXer
Littleton, CO
