Sailorsaint
- Jun 21, 2006
- 2
Motor runs fine until it overheats. Very little water coming from cooling ports, mostly a warm air. I figured I need a water pump replacement but when I removed all of the bolts that hold the gearbox to the exhaust housing it is loose, but doesn't release. The Clymer manual I'm using just says to carefully remove the gearbox. What am I doing wrong?
