bozza_boatie
- Apr 13, 2003
- 65
I need to remove a Flywheel on a 1982 Johnson 4hp. I do not wont to try the hammer method when you hit the flywheel with a hammer as I dont wont to break the crank. I know i cant buy a proper one, so I was thinking, Will this work.<br /><br />Get a dome nut and tighten it to the crankshaft thread. Then hold the flywheel by screwing 2 bolts into 2 of the 3 holes in the centre of the flywheel, put a spanner of a rod between them and hold. <br />Then if I continue to tighten the dome nut and hold the flywheel still, the flywheel should come off right?<br />Is this the same way a real puller works?<br />And Will this work?<br />And what will I do if it does not?<br /><br />Thankyou
