Welcome Guest - Sign Up today
No announcement yet.
kill switch problems on '83 Evinrude 60
This topic is closed.
  • kill switch problems on '83 Evinrude 60
    I have a 1983 60 hp Evinrude that is giving trouble on and off. I have now discovered the that the problem is a fault in the kill switch system. When I disconnect the kill switch then she starts and if I reconnect while she is running then she dies and I get a slight shock. She runs very well otherwise! Where do I start?
    Re: kill switch problems on '83 Evinrude 60
    Lady Jayn...are you talking about the kill switch on the control box? From where are you getting the shock....engine or control box?A shock usually means a bare wire going against metal. Look around the switch for any bare wire that may be laying against the metal.This is about all we can suggest until we have a little more info.
    When in doubt...use the manual
    Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
    • #3
      I am getting a shock on the black and yellow wire on the motor not in the control box - I have not opened the control box up yet. I disconnected the black and yellow wire at the connector on the motor and then she started - when I reconnected the wires at the connector on the motor she died immediately. Could the problem be in the control box at the ignition switch?
      • #4
        The black w/yellow strip wire is your kill wire from the power pack. It runs up to the key switch and is also wired into the emergency cut off switch mounted on the side of the control box. One of three things.....key switch is going bad, emergency kill switch is going bad or, again, the wire has a bare spot and is laying against a grounded metal part. If your getting a shock from the wire when you touch it, I'd be looking for a bare place in the wire near the engine.A wiring diagram would do you a lot of good. Do you have a service manual?
        • #5
          Thanks OBJ - I will check it out and get back tomorrow.
          • #6
            Outcome findings solutions?
            We are questioning kill switch on our 83 evinrude 60hp
            no manuel yet
            • #7
              This thread will go ----" boom "----As it is 13 years old.
              • #8
                AR - Start a new thread or wait for the book.
                Closed.
                BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
                Please, no PM's (Private Messages) regarding boat/engine problems.
                That is what the forums are for.
                Only forum/moderator issues will be answered in PM's.
