Hello all. Looking for some input on an outboard I am attempting to resurrect.
I picked up this one a few years ago with the intent on seeing if I could bring it back to life and I just got done breathing a little fire through her. It's been sitting on a stand outside for at least 4 years.
Rebuilt carbs, changed reeds (CCMS Sports), new coils, plugs, and new fuel pump. I used very rich fuel and sprayed some 2 stoke oil in cylinders and ran the starter a few times to coat walls. It has never been seized (in my possession anyway) and a compression test showed the following.
Cold compression test:
1- 120
2- 112
3- 122
I have a little fuel leaking from the choke solenoid...perhaps bad vacuum diaphragm? When I turn the red knob clockwise it stops leaking. Could not tell exact location of source but it was from the choke unit. What is the deal with that thing btw...how does that work. It has an "air fill" valve on it? Can someone explain that thing to me?
Anyway, it finally fired up, seemed to run "okay" (it ran)...then after about 30 seconds and hitting the throttle (only a little) I had some flames shooting out the bottom of the mid section. The lower unit is off and I have a hose running water directly through the up tube. I shut it off immediately, but wasn't sure if the flames were "normal" or something I need to make adjustments somewhere. It didn't seem to "backfire"...just flames. I didn't let it run to hear anything terribly wrong, but I wanted to get some professional input from you guys. Let me know if you have any questions and thank you in advance for any info you might be able to share.
1- 120
2- 112
3- 122
