Superduck1
- Aug 24, 2020
- 23
So started the year and things worked fine. The more I took it out the worse it has become. Sometimes upwards of 50 plus pulls amd it still wont start. It will shudder and then die. Back to more pulling. So far I have put new plugs in, took the carb off amd replaced gaskets and throughly cleaned with carb cleaner. Fresh premium gas with marine oil. Really the only way I can sometimes start it is with a bit of gas down the carb. I'm at loss of what to do or try.
