CPT MOTU
- May 8, 2015
- 15
I’m reaching out to get some fresh thoughts on my boat engine ‘’no start” situation. My 1994 Evinrude 2-stroke ELRM30 (30hp) in my boat wouldn’t turn over the other day (just a hum) after starting and running fine 7 days prior, including starting and running fine for many years. I immediately put my meter on the older battery and metered 12.5V. I popped off the engine cover and attempted another restart and saw the starter engage the flywheel but struggle to turn the flywheel more than 1/4 turn before humming again. I successfully pull started it (with the aid of starting fluid) and ran it around the lake for about 1 hour. After stopping at the sand bar for a couple hours, I successfully pull started it again and ran it for a few minutes before noticing my fast idle lever didn’t want to go all the way up (like a spring was preventing it from the max idle position). Weird. Then I noticed the engine RPM wouldn’t respond to my fast idle lever position (RPMs stayed low no matter what position the lever was at). Really weird. Then I shut the engine off to look at the linkage and cable. Then, I couldn’t get it to start after multiple attempts at pull starting with starting fluid (only got some “snorts”). Battery metered at only 10.5V at this point. I got towed to shore and replaced the battery. I stupidly reversed the polarity on the new battery connection and didn’t notice until I turned the key and observed complete silence. After saying “oh ****” and fixing the polarity/connections, I still could only get some snorts. I was worried that reversing the polarity for a second might have blown something, because I know that can be detrimental. Either way, I was hopeful that I might have just fouled the plugs and I just needed to verify a good spark and my starting fluid would do the rest. Two days later, I put fresh plugs in and verified spark (via in-line spark tester). I even verified that the old plugs had spark before putting in the new ones. I still can only get some snorts, during multiple attempts at starts. I’ve never had a situation where starting fluid wouldn’t bang after verifying spark. I did notice (and fix) one more thing after replacing the plugs: a thin braided ground cable was severed that goes from the starter to the engine chassis. Not sure how long it had been severed, but fixing it didn’t change my “no start” situation. Any thoughts? I suppose the spark that I “see” in my tester might not be hot enough under compression if the coils are lethargic all of the sudden. How else can a spark NOT ignite starting fluid (i.e. I’m ruling out a fuel delivery problem). Help!
