Good Afternoon all,
I am new to Iboats and I am very happy to have found this community. I just got a FREE boat and motor and it actually is awesome. The motor sounds strong when I tun it on dry land but a soon as I put it in the water it wont run. I am pretty sure I has everything to do back pressure. Basic check points completed:
spark
- I have double and triple checked the spark and even tried drop cyclender testing. Some slight changes but will do just fine.
fuel
- I just replaced the fuel pump and made sure all the basic fueling things are tight functioning.
- I have not yet cleaned the carbs but I did peak in them when I got the boat. I did not see anything major.
Air -Help
- this is where I could be confused . I think it might be back pressure in the exhaust if this the case how do I remedy it?
Also it seems this is not a strange thing at all... Has anyone experienced this and what was the solution. Also what is the likely hood that this is something simple.
more or less where do I start?
P.s. HHHHHHHEEEEEEELLLLLPPPPPP!!!!!!!!
spark
fuel
Air -Help
