Azcardsfan73
- Jun 3, 2020
- 6
I just bout a first boat. It's an old one i plan on fixing up. A 1976 Cajun mach1 bass boat with a 1960 Evinrude 40 hp outboard 2 cylinder motor. Model #35520.
Motor is not running. I tested for spark and found none. It's probably points/coil etc. I will be pulling flywheel soon. I do have several questions.
1) Does anyone know where parts can be found for this motor?
2) Whats the proper fuel/oil mixture?
3) Proper size plugs? Currently has champion J8.
4) correct point gaps?
5) I have read around net that people have gotten points, condenser etc. from Napa Does anyone know the actual part numbers.
Also I've read that lower unit should have gear oil changed how is this done and what is correct weight of gear oil.
I am mechanically inclined but this is my first time owning a boat or working on a outboard motor.
Thanks!
Thanks!
