1976 Evinrude 15hp fuel pump.
merkdawg0084
Ok guys, so I rebuilt the fuel pump. Carb doesn’t sputter
anymore. All good there. But the motor doesn’t seem to have as much power as I think it should. So I pulled bottom plug wire and motor still ran, bogged down a little bit. Put bottom wire back on, pulled top plug wire and it died? Bad coil? Points? Thx,
OldOMC31
Prior to pulling the flywheel, have you tired swapping the coils around to determine if the bottom coil works fine on the top cylinder?
