There is something you need to know. That is a thermostat controlled recirculating cooling system. The thermostat is constantly sampling the engine temp and opens and closes as necessary to maintain proper temp, Therefor the water you see exiting out the back varies according to thermostat state. But there should always be at least SOME spray. At idle speed and cold lake water, the thermostat might remain closed (SOME) light spray
