Rodman738
- Jul 7, 2017
- 40
Just picked up this 77 Johnson 6hp. Motor is clean the guy I purchased it from said it was running fine!!
coils plugs cdi box all look new.
Motor only will run from 3/4 to full throttle! When you back the throttle a little bit it loses spark in both cylinders.
i had another cdi box I switched out with no difference. I'm thinking the trigger under the flywheel? Or the coil under flywheel? Don't really understand what kills motor as there is no kill switch. Anyone ever had this issue?
