67 Johnson CD-24 6 hp Pinion has very little engagement with flywheel
N Navy diver Recruit Joined May 12, 2020 Messages 2 May 12, 2020 #1 67 Johnson CD-24 6 hp Pinion has very little engagement with flywheel
southkogs Moderator Staff member Joined Jul 7, 2010 Messages 14,792 May 12, 2020 #2 Navy diver - Please only start one topic on the same issue. I've moved this one to the Johnson / Evinrude forum and deleted the other. Welcome aboard.
M Mohawkmtrs Chief Petty Officer Joined Jan 13, 2010 Messages 561 May 13, 2020 #3 Check condition of battery and ensure all connections are clean and tight. Also ensure starter shaft where the Bendix rides is clean and lubed.
