Welcome Guest - Sign Up today
No announcement yet.
E-TEC 2006 225HP Diagnostic Report
  • E-TEC 2006 225HP Diagnostic Report
    Model: E225DPXSD
    Serial: 05117970
    E-TEC 2006 225HP
    A few weeks ago I was taking the boat out for the season. While driving to the ramp the engine started to lose power, bogged way down; right before shutting down the " NO OIL" light went on and it hasnt started since. I got to spend the next hour waiting for sea tow in the cold. I had added another gallon of oil right before shoving off.
    I ran a compression test and found:
    Port Starboard
    0 82
    0 83
    90 92
    I had some time to open up my valve covers this weekend and the following pictures are what i found.... Looks like the piston melted and the connecting rod sheared off. Surprisingly the rings were twisted but intact. I have some pictures below, any idea what happened? Can anyone see anything in these pictures that screams the block is shot? Or any signs of what happened that i am missing?
    Thanks for any help!
    Brian
    1992 16' Bayliner Capri; 70 HP Force- Currently dry docked
    Living at the beach in Lavallette New Jersey
    Current Project:
    https://forums.iboats.com/forum/engin...-force-rebuild
    Current Project:
    • #3
      Welcome to the big etecs...seen it many times. Hang a Yamaha 4 stroke on it if you like the boat.
      '47 18' CC Utility "Knock On Wood"
      Various Evinrude powered Pontoons all named "Floosy" I've realized that 1/2 the population is above average intelligence, wish I was in it.
      • #4
        ??-----Valve covers ??-----I would say you took off the cylinder heads.-------An example of " high tech " motors that need dealer support after a long period of inactivity.-----You have a " parts only " motor I believe.
        • #5
          I suggest you post your topic to the ETEC user board where the ETEC community concentrates . MY 75hp
          http://www.etecownersgroup.com/?forum=115573
          • #6
            Thanks for the helpful correction .... Im not following what you mean by long period of inactivity? I fish the boat on a very regular basis.
            Current Project:
            • #7
              Thanks for the suggestion I have a thread going there, havent had a ton of response.
              Current Project:
              • #8
                I guess the term -----" taking the boat out for the season "-----can mean different things.
                • #9
                  Typical piston pin migration problem that haunts big looper motors. That is officially now a parts motor as not worth having rewelded and sleeved.
                  When in doubt,Trim it out!!!
                  Business Owner & Certifed Technician
                  Boats I own & use
                  20ft Javlin w/250 Junkrude
                  17ft Bullet w/200 Merc (SOLD!!)
                  13ft Allison w/150 I-6
                  17ft Hydra-Sport 175GT
                  15ft Allison w/75 Stinger(project)
                  14 x 48 Drifter with 1100SS Merc
                  • #10
                    You win the award for the least helpful person on this page pal, "kick rocks" Ask your kids to unteach you the internet.
                    Current Project:
                    • #11
                      On more than one occasion folks on here have asked posters to explain what they mean when they say------" my motor won't crank "-----Apparently in some local areas that means that it won't start.--------In my area---- " taking the boat out for the season " ----Means it has been under a tarp for 6 months and this will be the first use !----But you are right I know nothing.---- And should just read internet like a comic book and enjoy in these tough times.
