Welcome Guest - Sign Up today
No announcement yet.
Opinions please.... 😊
  • Opinions please.... 😊
    Hi All,
    I am going to retire my 1988 Force 125h.p, and a new Evinrude E-tec 115 h.o g2 was recommended for my set up.
    I understand it's a new engine, but does anyone have any feedback or known problems with this engine?
    I'm going for power steering as an option, otherwise it will be stock. They say it doesn't need a service until 5 years, then every 100 hours..... Seems like a stretch.
    Any thoughts and feedback appreciated before I spend my hard earned!
    Cheers
    Make sure you start with the simple things first.Ask yourself- " IS MY BATTERY CONNECTED"
    NO, go Mercury or Yamaha maybe Suzuki.
    I'm all for buying American made but the BRP just isn't what I'd buy.
    I hear bad things about Suzuki warranty's. Not sure if they are rumors or fact???
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM I WON'T ANSWER AS MY SYSTEM CAN'T REPLY TO YOUR EMAILS
    • #3
      Do they not provide a 7 year warranty on these E-tec machines ?-------Correct there is no SCHEDULED maintenance required on the Evinrude in the first 5 years.------Run it full throttle out of the box !
      • #4
        Force weight 300 lb
        Evinrude 390 lb
        10 less hp and 90 pounds heavier, so performance will be impacted. Also the stern will set lower, check if this could be an issue for swamping on bilge pump exit port
        94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
        95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
        07 Seadoo GTX
        Merc Adults Only VP Adults Only
        G-Dad always said "First Liar doesn't stand a chance"
        • #5
          Go.for the E-tec, they are as good as anything out there with a great warranty.
          • #6
            Well I have a 2005 75hp ETEC which has been a dream ( very few minor things) starts on a dime every Spring launch
            after 6 months storage
            You should visit the Etec user site for specific comments on the G2 but if it is anything like or better than my 75hp
            it shoud be a dream engine. All motors have their qwirks , bad luck and lemons I guess
            http://www.etecownersgroup.com/?forum=115573
            I did have one issue on my early version "ETEC" no oil code 38s but it was fixed way past warranty by BRP
            so no complaints from me about BRP customer care.
            just change gearcase oil , use 2+4d stabilizer regularly and burn XD-100 oil for a NO SMELL NO SMOKE operation
            • #7
              Motor choice is different for every situation / budget.--------Dealer friend said that he " loves the 4 stokes " as they come in for regular visits.------Oil changes means fork lift fee . oil , filters / sparkplugs and $300 / $400 each invoice.-----That was for his " high end " customers.----If you can do this work at home it is different.
              • #8
                Originally posted by AllDodge View Post
                Force weight 300 lb
                Evinrude 390 lb
                No,etec h.o. motors are allowed to fudge the numbers by 10 percent .So the 115 is closer to 130hp non h.o.! I lost the link but this is allowed by the outboard standards org what ever its called.Only h.o. motors are allowed to do this.The h.o. 225 is actually 265hp!I believe continuous wave has several threads on this subject.The 115 will have a larger gearcase and gearing than the force also.O.P. why do you think the 5 year or 500 hr no touch motor service schedule is a strech?Did my 60 at the dealer at 3 years and the gear oil had barely turned color.Coming on 8 years of flaweless running and 4 years of that is on the xd100 setting which produces amazing oil ratio,s .Probably 250 to 300 to 1 at idle and well in excess of 100 to 1 at full throttle. My friend bought a 15 foot 1976 smokercraft that somebody had put a 115 etec on and besides the fact that the boat was way overpowered the motor was stellar.He did sell the etec but only for safety's sake and put on a small yammy.
                • #9
                  https://www.youtube.com/watch?v=l4vkmJcaW6I
                  fyi
                  • #10
                    All outboards are required to be +/- 10% of the hp rating. HO motors are usually on the higher side.of.that rating. Nothing to do.with just E-tecs Every manufacturer has had some kind of performance model.that pushes the + 10% #. If.I bought an E-tec I would have the oil pump set to Tc3 3 and run the best oil I could afford in it.
                    • #11
                      My apologies guys my math is out of wack today, the 250 ho was dynode at 265 plus. not the 225..My 670h.o. ski-doo mxz was reported to be 128hp but in reality was dyno tested at 140hp!Which explained wherei it got the name of 800 killer from.
                      • #12
                        Flyingscott I meant all h.o.,s not just evinrudes should of stated that more clearly,sorry for the confusion.Crosbyman if you let the vid continue on to the next one its even more telling and the numbers and test methodology are fair.
                        • #13
                          Really
                          And a boat test vid does make it so just because its in a vid. Boat test is bought and paid for by which ever company is paying boat test. There is nothing wrong with a motor producing more power then listed, only less, farm equipment has been doing it for years.
                          07 Seadoo GTX
                          • #14
                            Lets put this in a nutshell shall we. There are no bad motors anymore except for the chinese branded motors. Any motor from the big 5 is going to be a decent motor for you.
                            Your decision should come down to Ergonomics that is how comfortable the controls are to you. The warranty and dealer location should be what drives your decision.
                            • #15
                              AllDodge, did you watch the second vid?How can you dispute the facts on that one.If were totally on the wrong page please forgive me as im not looking for a fight .Simple fact is the 150 h.o. could get the boat on plane and the 200 Yamaha couldn't even produce 10 mph .Lots of independent tests come to the same conclusions also.Heck I like yamahas and would serious concider one if I was in the market but numbers don't lie.
