Welcome Guest - Sign Up today
No announcement yet.
To grease or not to grease?
  • To grease or not to grease?
    Should I put grease on the prop shaft before installing prop on a 15 hp Evinrude? Thanks
    In salt water ----YES.
    • #3
      As Racer said, YES in salt. I'll go even further - Always grease the prop shaft, salt or fresh water.
      The old Merc in my sig was and is used exclusively in fresh water. When I removed the prop the first time, it was a bear. A little bit of grease would have helped way back when and doesn't hurt when I install/remove the prop today.
      BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        yearly for me
        94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
        95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
        07 Seadoo GTX
        Merc Adults Only VP Adults Only
        G-Dad always said "First Liar doesn't stand a chance"
        • #5
          Same as above. Always grease. No downside, many upsides.
          '96 Larson 174 SEI BR. 4.3LX 4 bbl Weber s/n 0F786604. Alpha One Gen II s/n 0F709315
          • #6
            Ok, GREASE it is. Thx
