Welcome Guest - Sign Up today
No announcement yet.
175hp cylinder walls and absurd compression results
  • 175hp cylinder walls and absurd compression results
    Guys with more experience than me tell the compression readings I’ve been getting can’t be right: 60 psi on two cylinders, with the others showing 60 psi while cranking, but dropping to zero when I stop cranking.
    Word is that’s a bad gauge or I’m not using it right. But I got the same results with two different gauges. And it got 60 and held on some, but went to 60 and dropped on others. I was using the same gauges the same way each time. I’ve run compression tests lots of times on multiple engines. They’re kinyda hard to mess up. What could I be doing wrong?
    I pulled the heads and took pictures, which I’ll post below.
    It has been clearly stated that a compression gauge only goes to zero when you push the release valve on the gauge.----They do NOT go to zero any other way.
    • #3
      I wish I’d shot a video. All I can say is I watched it happen. I didn’t press the release valve, I just released the jumper switch that I was using to crank the motor. Time after time, two different gauges. I’m probably doing something wrong, but whatever it is, I didn’t press the release valve.
      Uploading photos now.
      • #4
        Starboard lower
        • #5
          Starboard center
          • #6
            Well, I lost track of my labels, so I’ll have to re-shoot, or I won’t be able to tell them apart. Not my best work!
            • #7
              Good idea !!
              • #8
                Two bad gauges....or leaking ones
                You know that you are a very poor driver when Siri says : "In 1/4 mile pull over and let me out...."
                • #9
                  The hole with the Siezco piston is worn out. Looks like it scuffed at one time and someone honed the crap out of it and slapped a new slug in der hole.
                  When in doubt,Trim it out!!!
                  Business Owner & Certifed Technician
                  Boats I own & use
                  20ft Javlin w/250 Junkrude
                  17ft Bullet w/200 Merc (SOLD!!)
                  13ft Allison w/150 I-6
                  17ft Hydra-Sport 175GT
                  15ft Allison w/75 Stinger(project)
                  14 x 48 Drifter with 1100SS Merc
                  • #10
                    So I’m looking at a rebuild, right? No way to repair just that one cylinder?
                    • #11
                      Decisions are based on FACTS.-------I would run to a machine shop and MEASURE the cylinders with some degree of accuracy.----Then decide what needs to be done.----Post the numbers here.
                      • #12
                        Originally posted by racerone View Post
                        Decisions are based on FACTS.-----.
                        Hmmm...You ever been married? 😏
                        • #13
                          Good luck with your struggle on this motor.
                          • #14
                            Since it looks like I struggled to use a compression tester, I may be an unlikely candidate to get accurate cylinder measurements without outside intervention.
                            But I do have two ASE certified mechanics in the church where I serve. I’ll get their help and post the measurements, Lord willing.
                            Might take a while. Snow coming soon!
                            • #15
                              MOD EDIT - A bit presumptuous to come from a 2 hour member.
