So I bought an Evinrude E175TRXCNB 175 hp last year and ran a quick compression test. All six cylinders showed 100-110 psi. I fired it up briefly on a stand.
it sat in the garage close to a year, then I moved it to the backyard to start getting it ready to mount on my project boat. It ran pretty lousy, then wouldn’t start at all.
I checked for spark. All six good.
I pulled the plugs and they had quite a bit of fuel on them and what looked like loose carbon particulate on them. It wasn’t attached to the plugs: you could blow the little pieces right off.
i cleaned up the plugs... still no start.
i checked compression again and they were all around 75 psi.
Two things: second test was done in much colder weather and with a different compression tester.
Could either of those things explain the drop in compression readings?
(PS... no, I didn’t go through the carbs before I fired it up! Always in a hurry...)
