Welcome Guest - Sign Up today
No announcement yet.
Evinrude 35 HP Elan, 3 cyl. 2 stroke
  • Evinrude 35 HP Elan, 3 cyl. 2 stroke
    hi.
    i need some help with Evinrude 35 HP Elan, 3 cyl. 2 stroke.
    motor starts very hard. runs poorly.
    i had cdi failure( no spark at 3 cyl). its realy expensive part. difficult to fix here in my area.
    now i instaled new(used one). i got sparks on al cylinders.
    i run few hours , but poor runing existed. motor dies cuple of time on slow speed runing.
    now i notice at 1 and 2 carb( counting from the bottom) fuel is dripping, its some kind mix white mix of fuel on 1 carb and
    fuel from 2 carb.
    fuel is dripping from inlet of the carb.
    choke is working by electic and manual mode.
    compresion si 7, 7,5, 8 bar
    all floats in carb are adjusted as paralel to carb body. needles and seats are fine, no signs of wear
    motor is diffcult to sart, but when starts runs very poor and dies after 20 seconds
    what can be the problem with this fuel dripping from the carbs
    looks like fuel is pushing back fro cylinders or is not sucking int cylinders.
    looked at leaves - looks fine
    Is the oil tank / oil injection still in service?----If it is it should be taken off and thrown away.----How many turns out are the slow speed mixture screws ?----Replaced the water pump impeller ?
    • #3
      oil tank is removed.
      water cooling is fine.
      carb slow speed needles are out 2,5 turns out. ( more or les)
      this fuel flowing back from the carb throath is hard to understand
      bottom carb is blleding in white mix
      • #4
        What position is the red lever in on the electric primer valve ?----Slow speed needles are set a DISTANCE out per the manual.----That is the initial setting.-----Must be adjusted after that when motor is on boat and in gear.
        • #5
          1. red choke arm is in electric mode ( pointing up)
          2. do you have manual for this motor ? to adjust carbs at least
          is it posible that cylinders is not sealed at crankshaft line and back preasure is pushing back fuel?
          • #6
            I have the manual.----I know how to repair this type of motor.-----I have 8 or more of these 3 cylinder motors for rebuild / parts too.
            • #7
              is it posible to get from you a manual? in pdf
              my email: raczekp1@o2.pl
              • #8
                I repair motors.----I am not a pdf / computer expert , sorry.
                • #9
                  ok.
                  so what's the problem is with this motor.
                  cdi is failing or inner problems with pistons/crankshaft
                  • #10
                    It sounds like your motor is flooding. Re-visit your carb work. Or maybe the primer is leaking through? link and sync done on that.
                    • #11
                      any help how to do link and sync on this motor?
                      • #12
                        Compression might be a bit low.------Remove cylinder head for a look.-----No head gasket there, just O-rings that you might be able to re-use.----I say the white in the carburetor is water from the air ( condensation ) on the cold carburetor parts.
                        • #13
                          tested all cylinders compression and i got 8, 8, 8 bar..equal on all cylinders.
                          removed head and cylinders looks good, honing patern very nice and visible., no scoring, like new
