I suspect the problem with this one is the inlet over the strainer popped a leak and in the process of replacing it myself and two other guys coon fingered it so I suspect the small spring may have toppled over. It worked for maybe 15 minutes after then quit pumping I've owned the outboard for nearly 30 years and never did much to it so I figure its time to do some replacing anyways.
