1976 Evinrude 70673D
Finally took it out on a small deep pond locally to try it out.
starts fine...put into gear and runs a little rough..throttle and would die if I did not hit
the choke a few times..and then runs fine at higher speeds.
Slow down before I can get to full speed (smaller pond) and sometimes could take back off okay...most of the
time have to hit choke once or twice.
I have taken this thing apart, bored out, new pistons and everything. Very excited to finally get a good manual and able to do the link n synch...I was having trouble figuring out.
what would be causing this to happen?
Thank you in advance
