10outboard
- Aug 12, 2019
- 5
I'm having a problem with the throttle with the throttle being stuck. I cannot turn the handle. I removed the screw holding the plastic throttle and the mechanism worked fine but when I reinstalled the handle, it did not work. It seems the 2 slots in the housing are lining up with the 2 locations in the handle and that's locking the throttle handle, Although there is a spring in the mechanism, the handle does not come out that 1/4 inch to free the handle from it's locked location. I'm confused and any assistance would be grateful. There does not seem to be any give in the shaft to allow for the handle to free itself from the locked position.
