Look for a steering tension screw on the lower part of the bracket. You also may have an issue with dried grease -- locate a grease zerk/lube fitting and see if you can pump in some more grease.
I assume you mean the mounting clamp bracket where the motor attaches to the boat? I found the zerk fitting and made sure it had enough grease. The motor actually swings to either side way too easily and I'm hoping to tighten the steering tension so it doesn't move so freely.
