2002 Johnson Enforcer Bogs Down
mbenko1
Anytime I accelerate motor bogs down.
Ive cleaned the carbs and replaced the entire stator assembly.
Starts and Idles no problem
Its a 2002 Johnson Enforcer 55HP two stroke Model #J55APRL
Here is a video of what is going on... https://youtu.be/07plcmUHBV4
Thank you
oldboat1
I'm not hearing the problem. Motor is in neutral, yes? Does it stumble in gear? (cannot operate above fast idle unless the motor is in gear).
oldboat1
On second look I'm picking up a lean sneeze, I think. Your motor is a 2003 model, and there is an idle adjustment needle at the rear of the carb top. Try slight adjustment of that needle -- initially rotate it counter clockwise about 1/8 of a turn and see if the idle smooths out. The needle adjusts the air/fuel idle mix (counter clockwise is richer -- more fuel. Takes some experimentation.
When correctly set, the motor will idle smoothly and will go into gear and accelerate without stumbling or stalling.
