While servicing my boat for storage last year, I found milky gear case oil. I changed the oil and left it at that. I'm wondering where I should start. Where could water get in? I've read that the prop shaft seals are the most likely cause, I attached a photo of a parts break down, are the seals I'm looking for #31? Drain and fill plug gaskets were changed last year. Any suggestions/comments would be appreciated.
