Morning All - on previous motors i've had there was a grey tach wire that ran up tot he control box. Doesn't seem to be the case with this 35hp.
Search uncovered it's directly wired to the rectifier (or i may be wrong there) - so i'm looking for a bit of insight on where it should be wired to for signal.
Also, to confirm, i've read i need to set on 5 pulse, not 6 for the 35hp?
Thank you!
Thank you!
