lindy46
- Nov 27, 2008
- 3,886
The tilt won't hold the motor up. When in full up position it leaks back down in about 30 minutes. No apparent fluid leaks and reservoir is full. I suspect the manual release valve after reading other posts. So I got replacement o-rings, and thought it would be a simple job. WRONG. I removed the circlip and proceeded to unscrew the valve. Got it almost out and it stopped - wouldn't come all the way out. I tried grasping it with pliers thinking it was at the end of the threads, but it just wouldn't pull out. What am I doing wrong?
