hardwater fisherman
- Mar 19, 2010
- 1,725
Last year the lower unit had a trace of water in it as the oil was milky.. It was stored indoors over the winter with new oil in it.. I ordered a seal kit last week and am still waiting for it. When i drained the gearcase there was some water and small metal flakes.The shift cradle was just hanging on to one side of the yoke and there was a small piece of it floating around inside... The gears and clutch dog look good.. I have two 9.5s that I have been using for pieces and it appears that all the parts are the same except for the gears.. So I hope to find a shift cradle in one of them...The yoke is also a little messed up so I will change that as well... Did the cradle break from the water inside or for some other reason?
