Model#85899C I have had intermittent firing problems (engine low on power, rpm's way down) I have isolated the problem down to one cylinder. I know the power pack is good and the coil is good. I have learned that the stator furnishes power to the power pack. My question is, can the stator supply power to only one side of the power pack, or is the wire from the stator to the power pack the problem? this is an intermittent problem. If the wire is bad can it be repaired or do I need to replace the stator? thank you for your help.
