Hello to all. I am new to the forum and boating and I Ihave run into a problem. So for a little background on my boat the outboard is a 1965 and a half 9.5 sportwin Evinrude. I just did a carb rebuild new JC4 plugs new fuel pump fuel lines gas tank.
The the boat runs fine and starts up in about 4 puls. And I can go a long time at full throttle but after running it wide open throttle for about 30 min it wants to die and I have a hard time getting it started. I have to wait for ten plus min and then it runs good for a short time then dies again. Does this untill starting it is almost impossible shorter and shorter run times in-between. It's been 90 plus degrees outside when I first noticed this happening.
Any ideas
thank you in advance for your time
Any ideas
