mhyder63ford
- May 6, 2010
- 54
i just resently got this motor. i have 125- 127 compression on all 4 cyclinders. when i got the motor it had a wierd shack. took it to local shop they said need carbs done, so they rebuilt them all. i get it back seems to run ok at first till it warmed up good. then it would sart to miss fire. so i put all new plugs wires and coils on. helped some. still a miss after warmed up but not as bad as it was. so i found a wire on the cdi box that was pinched all most in too. so brand new cdi box. now the new problem it is spitting fuel out of the low speed jets? it runs well on the hose idle is good just not sure about the fuel problem any help would be great thanks.
