Just purchased a 1991 Johnson GT150 the other day. Although the motor runs great there is no water coming out of tell tale. Took cover off and noticed the hose is missing off of barb fitting. First question is why would someone disconnect that and second where is the water going now? I’ve had it at the lake with cover off trying to see if water was pouring into bottom of block or a hose spraying every where inside but it’s all dry. Is it possible this motor doesn’t have one? Every outboard I’ve owned always pee’d. Owner did say he just had the water pump replaced at shop. I asked if he’s ever seen water coming out of motor and he never has.
