Hi, I have a 1984 Johnson 60hp outboard. I have been trying to find information on the carburetor and i'm hoping someone here might be able to help. My main issue, is I can't figure out how to set the air to fuel ratio on this carb. I am a total rookie and engine repair so I don't know a lot, but here is my issue. This carb has an orifice idle screw, and then a screw plug. What i'm unsure of is if the Screw plug is what controls the fuel air mix or if it's just supposed to be seated tight. If I loosen it, it just keeps spinning which makes me think it's just supposed to be seated tight, but I haven't been able to confirm that. If that is the case then is the idle just set by the low speed idle cable? The link shows the parts i'm talking about which are #9 and #30 Thanks in advance.
