Fishjustin87
- Aug 7, 2018
- 113
Can get the boat to start after priming the ball but it runs the ball out of fuel. I can keep it running if I continue to pump the ball. I tried the fuel rebuild and now I cant even keep it running. Opened it up again to verify everything is installed right and still no luck. I pulled the pulse hose off and i can feel pulse while cranking it over but it does not feel really strong. How much vacuum should the crank pull on the pulse line? Considering converting to regular fuel pump and bypassing vro system. What pump could I use for the conversion?
