Hello... I got an old sailboat converted to outboard boat with a 1987 50 hp Johnson on it. The guy I got it from said pump the bulb it'll start right up. Well, it starts and runs for a bit but then kills... and smokes a lot, I mean a lot. I've ordered the shop manual for the engine, but does anyone have any ideas on what I could do?
The gas and oil tank are below deck, the bulb on the oil tank is rock solid. As I said I am a complete newbie to outboard engines, but have worked on cars for a long time. I changed the plugs, but still only runs for a few moments. If I push the key in to choke it, it will run a little longer, but smokes very bad and eventually kills. Thanks for any help in advance
Bob
Bob
