Fishjustin87
- Aug 7, 2018
- 113
Starts cold and sounds good with the high idle lever slightly up. After running for about a minute or so and as it gets warm it dies. Even does this with the idle lever half up. Just rebuilt the fuel side of the pump so I dont believe it's that. It ran prior to me pulling it apart to replace the rectifier. The ball does seem to go flat and if I squeeze it pretty hard it will keep it going. I dont know what to check next. What should my fuel pressure be at an idle with an inline pressure regulator? I did have to remove the stator to do the rectifier. Did I mess up the timing when I did that? I did not touch the timer base
