I have a fuel leak that seems to be at it's worse after I turn off the engine. I am having a difficult time identifying the source of the leak. It seems to be coming from the carburetor bank and related fuel and recirc hoses. I rebuilt the carbs approximately 4 years ago and the engine runs great.
1. Are there any typical leak sources prevalent in these triple carb outboards?
2. Does anyone have any suggestions/tricks to help finding the leak? For example, should I spray the carb and hose area down with simple green to remove existing fuel/oil and then run engine to look for the leak? I also thought I read something about dusting the area with baby powder to help identify the source.
I'm looking for some help prior to jumping into this search. Thanks in advance for your help.
