Same motor, same problem after making some changes. I have an Evinrude, 1991 model E6REIA, 6 H.P. Not many hours on her at all. Had a new fuel pump put in last year and had the carb rebuilt at the same time. I was running it off of a water separator with my main motor, but I took it off of the separator (because of he problems I was having trying to get it to troll) and it is running directly out of the gas tank under my floor in the boat now, same tank as my main motor.
The kicker motor runs fine at 1/3 or more throttle, ( still hard to start though) but when I try to slow it down to troll, I get a little backfire type noise and it quits. Cannot tell if the backfire is from the carb or the exhaust, but being the exhaust is under water, I am leaning towards the little "pop" is from the carb. When is pops it stops running instantly, and even though the motor is warmed up after is has been running at half or more speed to get where I was going on the lake, I need to choke the motor when I pull the cord or she absolutely will not start unless I choke it. I turned the slow idle screw in and tried adjusting that today, and it actually made no differance at all where I turned it out to. Still had the same problem. Anyone that can tell me what to try next, I am greatful. Thank you!
