Tarinazo
- Feb 18, 2019
- 55
I got my hands on an overheated Johnson, did my research and found out that this thing tend to overheat. Lots of info in the web on what to do, so I did.
Had no spark, I changed the powerpack (solved it).
Changed fuel pump and fuel lines (inline fuel filter also)
Cleaned carb (although it looked brand new)
Took out thermostat, cleaned it to like-new condition, installed new rubber seal on it.
Cleaned all water pasages, also blew compressed air throug'em.
Dropped lower unit and put a new impeller kit.
Changed the famous upper tube grommet (yes, it was deformed and blocking).
Agter all this done, on my test tank it fired up on the 5th pull, then it would start on tha first pull without even pulling hard. Yesterday I took it out for a spin on my 1436 Jonboat. started with no problems and took for a 5 minute ride to my first fishing point. then another 5 minute ride to another point... wanting to get to my third point I struggled to start it, lot's of rope pulling and it finally started. after this it couldn't start, sore arm and blisters between my fingers.
I took the cover off and noticed that the head cover (not the thermostat cover) had a pink-brown color to it... I assume this is and overheat indication, right?
My guess is that it overheated, blew the powerpack and thus it wouldn'start.
So, now my question is this: Are this engines a sure thing they'll overheat?
Even after all I did to it previously?
