Johsnson Outboarder
- May 26, 2019
- 37
Bought my first boat a few months ago and it’s left me stranded on the water almost every time. First thing I replaced was the power pack to get spark. Then I took it out and it heated up and left me stranded. Started to read up and then replaced the water pump, stator, and trigger thinking one of those was the problem since I had lost spark until the engine cooled down enough. So then I finally try to address the heating up issue by replacing thermostats and I’m currently waiting on a new power pack since I’m not getting any spark again. Once I get it, would it be a good idea to take it out again with the new thermostats or is there something else it could be? The motor is a 1996 Johnson 130 that’s had the VRO system bypassed. Just did a compression test today and the results were 112, 113, 120, and 120 psi. Thanks in advance!
