Coosaguy
- Jun 13, 2019
- 10
I have a 1997 Johnson 150 Oceanrunner that I’ve noticed isn’t reaching maximum running RPM, only getting to about 4500, checked for spark, fuel, compression and all are present.
I found that two cylinders have no combustion when I was doing the compression check. I pulled the plugs on cylinders 1 and 5 and found that the plugs still looked brand new. They had fuel on them but they did not show signs of use. Put in and old plug and left the new one connected to the spark plug wire and started the motor. Spark is present on both plugs.
I’ve also tried disabling the shift interrupter switch and moving coil packs around. Compression check was also good. All cylinders within 5 psi of one another.
Im new to marine engine maintenance and 2 stroke maintenance so any help would be appreciated.
