somethingabouttheloons
- Apr 23, 2019
- 57
I have a Beautiful1960 Johnson JW-16 3hp motor that I have gone through and rebuilt the carburetor.
I should note that I have never rebuilt a marine carb before. I bought a shop manual and went
by it's instructions. Pretty easy as I am accustomed to mechanical work. Problem is when I start
the motor it only runs for a couple seconds and "floods". Fuel is actually running out the front of carb
where air silencer is attached to carb and the plugs are wet. It looks too me that I have the float set
parallel to the carb body as the manual I have shows. I am assuming the valve is just not seating and allowing
too much fuel to flow?
