Johsnson Outboarder
- May 26, 2019
- 37
I bought my first boat a couple months ago and since then I’ve gotten it to start, but this thing keeps leaving me stranded out on the water!
When i first got it, I first had to replace the Power Pack and spark plugs. I’ve gone out at least 5 times to different bodies of water and it seems to run like a champ for a while at different speeds (averaging about 25-35mph for a good 30 minutes up to a couple of hours). Then, I go to turn it off (to fish for a while), and it will NOT turn on again for at least 45 minutes to a couple hours.
During that time TODAY, I checked for spark and for fuel and I got plenty of fuel going to the carbs, but no spark at all.
What could cause intermittent spark distribution?
Could the power pack be bad AGAIN?!
Could my water pump (impeller seems to be forcing water out a little weak) be the cause?
(Note: I removed the wire to the ignition alarm to avoid having to hear the constant beeping sound last week. It also had a very bad connection and would stay on randomly from the moment I turned the key)
