I have a 89 Johnson 48hp motor with a bad lower unit I have acquired a 93 48hp evinrude lower and to me the only thing that appears different is the shaft mine is tapered at the top spline where the 93 is not can I just put my shaft into the evinrude lower and trim it or are there other compatibility issues I will be facing with this thanks in advance.
