Walleyehunter762
- May 22, 2019
- 15
I have a 1984 40 hp Evinrude, last summer it ran fine the whole time I took it out every weekend always use 91 octane and ethanol treatment and the motor was rebuilt the year prior to me buying it so parts are all new or rebuilt. This year it has been rubbing completely fine at full rpms for as long as I want but as soon as I stop for more than 15 minutes the lower cylinder floods getting the spark plug wet so it will only run on when cylinder when I restart it for about 10-15 minutes until the spark plug dries out then I can drive at full rpms again. I believe this to be a problem with the carburetor which I will be rebuilding this weekend for good measure, also I ordered a new choke solenoid which may be why it’s flooding.
The new main issue now is I have no power or anything when I turn the key, i ordered a new starter solenoid but found a fuse (I’ll include in pictures below) that connects to the starter solenoid today that is burnt out, I’ve also heard people talking about a 50 amp breaker I need to reset but don’t know the location of. I have a brand new battery and all connections are clean, has anyone had issues like this before? Any help on either issue would be much appreciated thanks!
